PCMforLess.com Tune for the Rainier
My new PCM will be here tomorrow by the time I get home from work.
I need to take a baseline run with the stock tune before I swap the PCM over and then I'll take a tuned run. My AutoEnginuity scanner will tell the tale.
I had them tune it to premium fuel, towing, and shift firmness of 2.
Well la dee da! Someone's made of $$$
Can't wait to see the differences. I have read a bit about the tune jobs and what they are supposed to produce. Will be nice to get a look at the actual numbers involved im for you
Actually, this is cheaper than the alternative. I have been having some issues with the truck stalling when on a slight incline and letting off the throttle to coast a bit, then getting back on the throttle (damn fly by wire). Local dealership wants $90 to "diagnose" the problem and states it'll be another $90 to upload the update to the PCM to cure the problem (per the TSB I have quoted them). They will not just upload the update for $90. The PCMforLess tuned PCM is costing me $200 total, $150 if I decide to send my PCM back to them. Cheaper alternative with added bonuses.
PCMforLess states their tunes can run on one step lower in octane with minimal loss of the benefits. Since I get better mileage right now with 89 than 87, I currently run mid-grade 89. Premium (93) is only another $0.10/gallon more which amounts to just over a dollar more per week for me. Not a bank breaker by any means.
BUT it's like drinking Patron when everyone else is drinking Cuervo. You get just as drunk, you just look much cooler doing it
Either way, i can't wait to see the difference
Well, a little delay in this project... New PCM arrived, but the box was damaged. I installed it anyway to see if the damage to the box affected the PCM. Well, it did... I could not get my scan tool to connect to the PCM and on an initial test drive, the ABS & Brake lights came on and the truck was locked into 2nd gear. PCMforLess will be sending me out a replacement. Kinda stinks, but it is hardly their fault.
Interested in the outcome of this...
wow. Anti-climax....
Hope the new one gets there quickly.
You're telling me!
NOOO!!! I hate cliffhangers...
That sucks.
Hope the next PCM will work.
That sucks.
I'd like to find out... They do not have the replacement on hand at this moment to ship back to me... I'm hangin' here too!
