2" or3" body lift
Old Jan 19, 2011 | 06:33 PM
wGraves's Avatar
wGraves is an unknown quantity at this point
I think 33's would be really bad. I rub with the 31's when I hit a big bump. I also still need to get some shackles and crank the t-bars some more. I have a good 1.5 inches cut out from each fender. I might try to if I can find a good deal on them. I always liked the tucked look.
Old Jan 19, 2011 | 09:25 PM
neo71665's Avatar
I would go ahead and shop for front diff parts if you plan on keeping 33s on it.
Old Jan 20, 2011 | 12:10 AM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
I would like to fit 32s on mine but i dont really wheel my blazer just take it to a few fishing spots is all
Old Jan 22, 2011 | 06:10 PM
98BlazerBoy's Avatar
98BlazerBoy is on a distinguished road
wow that looks nice.....u didnt have to extend the stearing rod? and did you have to extend alot of wires?
Old Jan 22, 2011 | 06:38 PM
69chevelle's Avatar
69chevelle is on a distinguished road
I ordered the 2" kit for mine but was backordered and a month went by and I got fed up and just got a 3" 1st gen kit. In the end I was glad I did or I would be kicking myself for paying more to get 1" less lift.
On mine I had to extend the wire that bolts to the firewall on the passanger side(ground wire) and I grabed new hose to extend the filler neck. the fill is 2" and the vent is 5/8" if I remember correctly.
No I did not have to extend my stearing rod, but I can't gaurentee you would need to
Like was said previously, you need to cut some of the lower reinforcement of the bumper out(which makes it so you cannot tow with the rear bumper, I have a hitch so this didn't affect me)
I think I have pics in my garage of the 3" BL, if not check my build thread.
33x10.5's will most likely rub. The place you will mpst likely rub first with stock wheels is the sway bar and/or frame. you will need to trim. I'm running 32's and they BARELY tuck in the rear,
I feal like a broken record..... use the search... 3" body lift 2nd gen.... there are threads out there with the info you seak!
MWP
Lifting Tech
Jan 18, 2014 07:07 PM
Cojack2
Lifting Tech
Nov 18, 2010 03:55 PM
jgaudu007
Lifting Tech
May 23, 2010 10:20 PM
Spectreblazer
Mar 9, 2010 10:33 PM
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
