Played in my feild/swamp today....vid inside
Old Nov 12, 2008 | 04:14 PM
RolingKCBlazer's Avatar
RolingKCBlazer is an unknown quantity at this point
Default RE: Played in my feild/swamp today....vid inside
i can move the shifter all day long but 4x dont enguaged.
Old Nov 12, 2008 | 05:05 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Have you searched the forum for a 1st gen fix for that?
Do you have to pull a lever to activate your 4WD?
Old Nov 12, 2008 | 08:23 PM
ORIGINAL: mysons95
Have you searched the forum for a 1st gen fix for that? Not yet
Do you have to pull a lever to activate your 4WD? Yes
Old Nov 13, 2008 | 05:12 AM
mysons95's Avatar
Search though the forum for your problem. My truck is a 2nd gen. I have the push button 4x4. I had to replace my vacuum 4x4 system with a pull cable system. That fixed mine. But I'm not as familiar with your system.
If you can't find a fix, then repost your question with an accurate subject line and someone should be able to help you.
Use a subject line something like... 1st gen 4x4 not engaging or something like that and then explain in detail your problem.
Old Nov 13, 2008 | 05:05 PM
yeah, im gunna replace the accuator and 4x4 indicator sensor this weekend if that dont fix it ill post somthing up.
Old Nov 13, 2008 | 06:04 PM
mysons95's Avatar
So, with your pull lever, you still have a vacuum actuator?
If so, here is my how-to on replacing the vacuum actuator with a locking pull cable.
Old Nov 13, 2008 | 08:25 PM
yeah i was also thinking about picking up that cable next weekend when i have the extra money.
1998blaz
Oct 2, 2013 09:22 PM
LuvMyTJ
Dec 17, 2009 06:51 PM
Renthorin
May 4, 2009 12:06 PM
SniperX13
Jan 29, 2007 12:09 AM
XBlazer01
May 13, 2006 12:38 PM
