'01 4X4 front bearing/hub change
Old Mar 2, 2008 | 10:54 AM
johnsonmopar's Avatar
johnsonmopar is an unknown quantity at this point
Default '01 4X4 front bearing/hub change
Hey I have a 2001 4 wheel drive blazer. My front bearings seem to be getting bad. From what I see you need to change the whole hub. How much work is it? Does it take to long? Any special tools needed? Thanks for any help, Matt
Old Mar 2, 2008 | 11:41 AM
Chevy Lover's Avatar
Default RE: '01 4X4 front bearing/hub change
This is from the DIY section, lots of helpful info in there.
https://blazerforum.com/m_56421/tm.htm
Old Mar 9, 2008 | 10:36 AM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Hey guys, my 4WD 2001 Blazer LS 2 dr (170 000 km)may also require the replacing of the wheel bearing/hub assembly, a few questions first off. Is it worth doing both sides at once? or just the side the reallt requires it? Also since your doing work to the hub assy, is it worth changing anything else (ball joints etc?)...any info. would be appreciated
ZR 2
Old Mar 9, 2008 | 11:19 AM
I would only replace the one side when it comes to wheel bearings. While you have everything apart, I would atleast check the ball joints and give them a good shot of grease, but if it ain't broke, don't fix it.
Old Mar 10, 2008 | 06:49 PM
ZR 2's Avatar
If you let a bearing assemblygo too long, what will happen? (i.e. will the wheel fall off, will it tug on the CV shafts and ruin those, etc.)Asking cause i'm waiting for the weather to warm up here in Toronto so i'm hoping not to do to much damage/wear & tear to the other components.................thanks
Fusefinder
Jul 12, 2010 10:14 AM
88s10Blazer
Jun 4, 2010 04:56 PM
Marcin
Nov 9, 2006 11:31 AM
Chavez96
Sep 20, 2006 04:04 PM
greengoose89
Aug 3, 2006 07:32 AM
