'02 Rear End Suspension
Old Jul 17, 2009 | 12:58 PM
rideus74's Avatar
rideus74 is on a distinguished road
Default '02 Rear End Suspension
I've had my ZR2 since 2002 and have pulled a trailer on the weekends with band gear. About 350 tongue weight. Regardless, the rear end always appeared to set lower, even when I bought it. I'm thinking the rear shocks have seen their better days but not sure (how do you know?). Is the rear end setting lower an inherent aspect of the vehicle? Is there anyway to correct it? Thanks!
Old Jul 17, 2009 | 03:55 PM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
Normally the s10 tilts forward (the front is lower)...if you have been pulling that much probably add-a-leaf wouldn't hurt either
Old Jul 17, 2009 | 04:20 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
the sagging rear is a fairly common issue with the 2 doors, i highly doubt your shocks are bad(unless your ride is bouncy or feels like your driving a boat) the common soultion to this problem would be an add a leaf as previosuly mentioned(less expensive) or a whole new leaf spring pack which will be expensive but IMO is a better route to go.
Old Jul 17, 2009 | 05:40 PM
rriddle3's Avatar
[quote=rideus74;232588]...I'm thinking the rear shocks have seen their better days but not sure (how do you know?)...quote]
Shocks have nothing to do with suspension height. You can remove them and the height would not change. That is controlled by the springs. To see if they are worn out, push down hard on the bumper about 3 times and release. The vehicle should stop bouncing after no more than twice.
Old Jul 28, 2009 | 08:14 AM
rideus74's Avatar
Great, thanks for all the great info guys, never thought about the leaf springs. Think the shocks are fine. Now I got the bug to do more after-market stuff to it after finding this site.
Old Aug 6, 2009 | 12:14 PM
Rottidog's Avatar
My '02 2dr. sags too. I got 2" blocks that fit between the leafs & diff. When I put them in & then give the T-Bars a 3/4"-1" twist (& a trip for a 4 wheel alignment) it'll sit with a bit of a rake forward to it. Should be very nice & under $100 for the blocks!
Old Aug 6, 2009 | 02:14 PM
mikeinwi's Avatar
do you plan on lowering your blazer?? unless youve done a spring over axle swap the blocks will lower the rear of your blazer if you want to lift the rear youll have to either get shackles, aal, or new leaf springs.
Old Aug 6, 2009 | 02:21 PM
Big Keith's Avatar
Big Keith is on a distinguished road
I have a 98 ZR2 & just put on a add a leaf kit very happy with it mine was sagging but looks good now. look in my post you will find all you need
Old Sep 29, 2009 | 10:56 AM
raydulce's Avatar
raydulce is on a distinguished road
Default Bringing back the post
Yeah, sorry guys. I know its been a few months since this post was active, but I have the same problem described. My 2001 blazer is sagging pretty poorly in the rear. My shocks are good as the truck recovers pretty quickly. My leaf springs are flat and i'm almost down to the bump stops.
What would you guys recommend?
1) Replace leaf springs (wouldn't they just sag again soon)
2) Add-a-leaf
3) Helwig Helper Spring
4) Helper Air bags
I'm thinking that (1) is probably the GM recommended solution. (2) would be nice because I'd like a little more capacity anyway as I always have stereo equipment in back. (3) really no comment because i've been told this is a way to add capacity and not fix my problem. (4) my favorite i think. Air bags would allow me to air up when towing and air down a little for just normal driving.
Thanks!!!!
Old Sep 29, 2009 | 11:16 AM
You can have your current leaf springs re-arched. There is a pretty good shop close by to me that does them for fairly cheap (a lot less than a new set costs).
I would either install new springs or re-arch your current springs first, then either add a set of load adjusting shocks (either coil overs or the Monroe air shocks) that will help support heavier loads. Add-a-leafs will raise the back end up, but will not really correct the problem at hand and probably will make your truck ride worse.
doktornasty
Nov 3, 2013 03:12 AM
787
Aug 7, 2012 08:18 PM
brino1
Feb 25, 2011 08:05 PM
Rottidog
Jan 26, 2010 07:37 PM
BlazerGuy2001
Suspension Tech
Jan 5, 2010 06:47 AM
