05 Blazer grinding noise not coming out of 4wd?
Hello, I Just purchased a 2005 2 Door blazer. When we took it for a test drive it worked great in both 2hi and 4hi but after a 2 hour drive we were slowing down on the off ramp and a loud grinding noise started coming from the front passenger side (sounded like a tire rubbing on a wheel well) When we slowed down so did the noise. My relative is a retired mechanic so he pressed 2 hi again and backed up and it seemed to work fine again until i slowed down to pull into my driveway it started again like a big rig gearing down and stops when i cut the tires. What could this be? I am kind of upset because i just bought it. Only has 70 000 miles. Thanks
EDIT: Heres a video of exactly what mine sounds like except mine does it at a lower speed. (the video is not my truck)
Last edited by Amart88; 01-07-2013 at 04:45 PM. Reason: adding example and type error
Also, If it matters there was alot of snow and slush on the roads and windy.
I will be trying to diagnose the problem tomorrow or Wednesday hopefully.
As stated, this is a some what common problem. So much so that I created THIS THREAD discussing the topic. That thread, and many more like it can be found in the often over looked Tech Article (DIY) section.
UPDATE: Today I took the battery out and removed the vacuum actuator part out from below it and it turns out that it is leaking so it wont hold its vacuum. I am going to get a new one tomorrow and go from there.
justblazin1
10-19-2014 11:12 AM
Sofaking819
08-09-2010 07:07 PM
Billy Jackets
12-22-2009 07:32 AM
jawsjr01
11-08-2008 10:56 AM
