1992 s15 GMC jimmy 4x4 problems
Sorry if this is in the wrong section, if so mods please move.
Ive searched alot on this, and i believe i have a small vacume issue, but thats not my real problem AFAIK.
When 4x4 does finaly engage after a couple trys. when i go down the road with it, it pulls on itself really bad, and sorta chugs as it goes down the road. After a couple miles or so it stops, and drives decent for awhile then it comes back. Im thinking possibly front drive shaft, or u-joints.
Let me know what you guys think, Thanks Kody.
*Moving to Steering, Suspension, & Drivetrain*
Does it feel like the drivetrain is binding up? If so, have any of the axles ever been swapped? Maybe they didn't match up the gear ratios properly?
I had the drivers side cv replaced at time of purchase, but it did it on the test drive with the original one in also, or original afaik. how would i go about checking for correct gear ratio for the transfer case, and cv.
anyone?
With all 4 wheels off the ground, vehicle supported on jack stands to the frame, mark a common spot on each tire (say 6 o'clock). Then engage the 4wd, put it in gear, and count the revolutions of the front and rear tires (making sure that all 4 tires are spinning). You should end up with the same number of revolutions both front and rear.
Another thing to check is that all 4 tires are the same size. If any one tire is off, it will cause the drivetrain to bind when in 4wd.
Alright thanks for the tip. So if the gear ratio is off how do I go about fixing this? I sound like such a noob to 4wd haha. I'm just more use to dodge's,mitsu's. just bought this jimmy as a winter beater so I could park my evo.
You would have to get the gear set replaced to match. You could do this in either the front or the rear axle (rear is easier IMO). But check the tires first. That is a more plausible explanation.
Well I checked all my tires and the ******* that had it before me put 2 different size tires on the front. Passenger is a 205/70, and driver side is a 215/70. So I'm guessing this is where my hoping/ pulling going down the road problem is coming from.
That could do it. It doesn't take much to cause bind.
well i got all new, and same size tires put on haha. 4x4 works like a dream now. thanks for the help everyone.
Advantage049
02-11-2011 04:59 PM
1993gmcjimmyW
06-30-2010 10:02 AM
