1996 blazer rear end ID help
Old May 2, 2014 | 07:05 PM
BlazerBuilder's Avatar
BlazerBuilder is on a distinguished road
Default 1996 blazer rear end ID help
there is no sticker in the glove box of my 1996 blazer, 2 dr. i'm trying to identify the rear. I found these numbers stamped on it but don't know what they mean, any help is appreciated! one stamped along the bottom on the side where the drive shaft bolts is '26041413' and another one on top stamped '277' there was also a stamp 'gm' with an unidentified number along with it
Old May 2, 2014 | 09:20 PM
Jamaroon's Avatar
Auto or 5 speed?
If auto then it's most likely the GM 7.5"
If it's 5 speed it could have a GM 8.5"
If you're asking about gears, most common are 3.42's
Attached Thumbnails 1996 blazer rear end ID help-gm10-bolt-75.jpg   1996 blazer rear end ID help-gm10-bolt-85.jpg
Old May 28, 2020 | 11:00 PM
Jeff Mounts's Avatar
Jeff Mounts is on a distinguished road
What is it and what is the gear ratio
Old May 28, 2020 | 11:13 PM
Default 4x4
[QUOTE=BlazerBuilder;626175]there is no sticker in the glove box of my 1996 blazer, 2 dr. i'm trying to identify the rear. I found these numbers stamped on it but don't know what they mean, any help is appreciated! one stamped along the bottom on the side where the drive shaft bolts is '26041413' and another one on top stamped '277' there was also a stamp 'gm' with an unidentified number along with it[/QU myOTE]
Old May 29, 2020 | 12:38 AM
Refer to Jamaroon's post about the size, it's most likely a 7.5. But as far as the gear ratio goes, without the sticker in the glove box, the only other real way to find out is to either call a dealership and have them decode the vin (if you physically go to the dealership, they might even be kind enough to print you out a sheet with all the RPO codes on it for you Blazer per the VIN), or pull the diff cover off and see what numbers are stamped into the side of the ring gear.
Old May 29, 2020 | 10:09 AM
I'm guessing he probably figured it out by now.
jdh420
Jan 17, 2016 12:43 PM
emartin
May 19, 2013 11:09 AM
_HeC_
Jan 22, 2012 06:32 PM
Kemper9388
Aug 24, 2011 11:03 PM
jagblazer01
Dec 1, 2008 12:17 PM
