1998 s10 blazer no 4wd indicator lights or 4wd
Good Evening, I have a 1998 blazer and I replaced to vacuum lines and checked all fuses. I still have no indicator lights on my 3 botton 4wd switch or any noise from the TCCM or the encoder motor on the t case? This has me stumped if anyone has information please help??. Have a blessed night.
Actually test voltage at the TCCM connections. I'm sure your's is like mine. So you will have the 4 pin and then the "tons of pins" connector. You should be able to find a schematic online. Check for corrosion.
Just an FYI, I tested everything, I have voltage, all new parts, and still I have no dash lights or AWD. I hate GM for this "we're gonna make your life easy" BS.
The Beast
26
Jan 15, 2014 10:55 AM
vetteandblazerman
Oct 29, 2009 03:57 PM
