1998 s10 blazer no 4wd indicator lights or 4wd
Old Oct 29, 2018 | 06:46 PM
Clintgunter's Avatar
Clintgunter is on a distinguished road
Default 1998 s10 blazer no 4wd indicator lights or 4wd
Good Evening, I have a 1998 blazer and I replaced to vacuum lines and checked all fuses. I still have no indicator lights on my 3 botton 4wd switch or any noise from the TCCM or the encoder motor on the t case? This has me stumped if anyone has information please help??. Have a blessed night.
Old Nov 4, 2018 | 10:29 AM
BravadaJunk's Avatar
BravadaJunk is on a distinguished road
Well since no one else has chimed in, and I'm having problems too, here's my suggestion.
Actually test voltage at the TCCM connections. I'm sure your's is like mine. So you will have the 4 pin and then the "tons of pins" connector. You should be able to find a schematic online. Check for corrosion.
Just an FYI, I tested everything, I have voltage, all new parts, and still I have no dash lights or AWD. I hate GM for this "we're gonna make your life easy" BS.
s_merrick
Feb 24, 2023 02:01 PM
bugsbunny16374
16
May 14, 2014 07:01 AM
The Beast
26
Jan 15, 2014 10:55 AM
AMACK
Nov 24, 2010 06:42 AM
vetteandblazerman
Oct 29, 2009 03:57 PM
