2" lift shackles
Old Apr 5, 2014 | 06:01 PM
nbguide's Avatar
nbguide is on a distinguished road
Default 2" lift shackles
I notice with all the lift shackles their is no bushing that comes with them. Is their a bushing I need to buy to put them on?
I'm putting new leaf springs on my 98 blazer ls and was going to put the 2" shackles on also. I know their is a bushing in the leafspring but I'm unsure if their is one on the top of the shackle, or is it just a through bolt
Thanks guys
Old Apr 5, 2014 | 06:42 PM
newguy's Avatar
Being a 98 you will most likely have to drill or burn them out. So yes you will need new ones for the frame
Old Apr 5, 2014 | 09:20 PM
chevy fan302's Avatar
chevy fan302 is on a distinguished road
i did mine without changing out the bushings but it night depend on the shackles i got the ones that give you the option of 1,2 or 3 inches of lift still need new leafs though seems they are completely flat and starting to bow the opposite way at the ends
Old Apr 6, 2014 | 02:33 PM
nbguide's Avatar
Thanks guys. I'll let you know how I make out. Springs should be here tomorrow
Old Apr 6, 2014 | 03:40 PM
newguy's Avatar
If you cant get the upper bolts out of the sleeve, use a sawzall or cut off wheel to cut the head of the bolt off. What I did next was to drill the rubber out of the bushing. Also had to use a chisel and hammer to get the outer sleeve out of the frame. Good luck. It goes easy for some and not for others
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
