2000 2DR 4x4 blazer torsion key mod?
Old Jan 2, 2011 | 08:47 PM
blackblazer00's Avatar
blackblazer00 is on a distinguished road
Smile 2000 2DR 4x4 blazer torsion key mod?
im new to the idea of lifting a vehicle i am trying to do everything on a very cheap budget i am having custom shackles made for the back to raise the rear end 3 inches. I was playing around with the torsion keys and discovered that if i was to remove a small section out of the top of the cross member that holds the keys i would be able to gain about 3/4 of an inch extra travel. my plan is to weld a u shaped piece of 1/4 inch thick flat bar over the hole to add back the strength the hole had taken away. Will this idea work? any insight would be greatly appreciated.
thanks, Brad
Old Jan 2, 2011 | 08:48 PM
I hope you have lots of money set aside for ball joints & CV shafts because you are going to need it. You can tweak the torsion bars so far with no modifications to blow through those items, why would you want to go even further?
Old Jan 2, 2011 | 10:07 PM
my goal is to run 33s will tweaking the stock keys give me enough lift so tires wont rub? I already have a 3inch body lift and planing on custom shackles
Old Jan 2, 2011 | 10:36 PM
mdehoogh's Avatar
Rather than cutting the crossmember to raise the stock key further, you'd be better off replacing with aftermarket keys that rotate the bar as much as the stock keys do while maintaining the stock position of the key itself. It would allow you to crank them the highest.
You will wear out CVs and balljoints like swartlkk said however there are some available with lifetime warranties (although operating outside of factory spec ride height may void the warranty). Also due to the design of the control arms, the higher you go, the harder it is to align the wheels/tires. If it can't be aligned properly, you could also wear out your tires quickly.
If you're willing to cut/trim the fender to help make room, you might fit 33's. I know of two or three members that have 33's on the tbar crank/body lift combo but I think it's a pretty tight fit.
Old Jan 3, 2011 | 03:35 PM
ok 31's it is lol thanks for the insight guys!
Kevin Cody
Jun 30, 2013 07:28 AM
chris015
Engine & Internal
Jul 2, 2012 01:04 PM
filoblazer
Lifting Tech
Aug 29, 2011 06:07 AM
hammer051
Lifting Tech
25
Jan 16, 2011 02:44 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
