2000 Blazer Rear Diff Cover with Fill Plug?
Old Mar 29, 2017 | 04:10 PM
Josh Smith's Avatar
Josh Smith is on a distinguished road
Default 2000 Blazer Rear Diff Cover with Fill Plug?
Hello,
I'm wondering if there is a rear differential cover out there that will fit a 2000 Blazer (non-G80) that has a fill plug.
The plug on mine is seized and rounded out. I've filled through the drain vent but that takes forever.
It's about time to drain and fill again, and I'd rather just add a rear diff cover that has a drain hole. Heckuva lot less bother than drilling the seized one out, and easier to get to besides.
Any help?
Thank you,
Josh
Old Mar 29, 2017 | 04:50 PM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
The same thing happened to me. When I go to do it again my plan was to drill out the center of the rounded plug and tap it with probably a M14X1.75 hex head oil drain plug. To answer your other question, no they do not make one for the non g80 Blazers.
Old Mar 29, 2017 | 05:54 PM
TA Performance TA-1809 Girdle Cover TA Performance TA-1809 Girdle Cover
- Pricey, but has what you want.
Or buy a
new steel cover new steel cover
and add your own fill port to it. Much cheaper, but only if you know someone that would weld it up for you. If you go this route, just match the height of the original fill plug on the axle center section with the bolt holes to make sure the level is correct.
caseroj
13
Mar 4, 2012 07:43 PM
j89lumaye
Jul 6, 2011 02:13 PM
razman
Apr 5, 2010 10:15 AM
SCPratt
May 4, 2009 02:53 AM
boulonman
Mar 5, 2007 05:10 AM
