2001 Chevy blazer not engaging into 4x4
The 3-button system isn't all that intelligent when it comes to engagement. From what you have stated, it would appear as though the encoder is functioning properly and it is something in the front axle that is at fault. You'll have to dig into it and inspect the engagement mechanism further to see what's really going on in there. I have seen the engagement collar break apart in the past which leads to no engagement, but all other inputs to the TCCM lead it to believe that everything is locked in properly.
Would it make any noise? It drives very smooth with no noise. I was just hoping it wasn’t anything internal. If internal still something I could DYI? Im pretty handy and always do my research b4 digging into anything.
If the front driveshaft is locked in 4WD, which you say it is, with the engine running elevate the right front wheel and see if you can rotate in either direction. If
it only moves a little and stops in both directions, then the axle is locked in too. If not, look at the vacuum, front axle actuator, and front axle actuator cable.
Then we can go from there.
Bill
Bill
Carls01blazer
12-19-2013 10:13 PM
orange&black90
10-15-2012 04:15 PM
