2004 blazer
Old Dec 20, 2010 | 05:37 PM
nor cal bob's Avatar
nor cal bob is on a distinguished road
Default 2004 blazer
have 04 wont diengage from 4x4 to 2 high when i try 2 wheel light comes on but front end howls.will shift back to 4 high howl goes away any ideas.
Old Dec 20, 2010 | 08:23 PM
Your front axle is not fully disengaging. This could be due to a frozen engagement cable or from a broken return spring inside the front axle.
Old Dec 21, 2010 | 09:33 PM
will check engagement cabl how difficult is the return spring to replace in the front acle
Old Dec 22, 2010 | 06:39 AM
To even check the spring inside the front axle passenger side extension housing, the extension housing itself needs to be removed.
The picture below shows the spring in question:
Old Dec 23, 2010 | 04:02 PM
Default 4x4 disengage
thanks for the pic and the info really helps out alot,this is my first blazer project,and i find you all have been extremly helpful in getting this project off the ground.happy holidays..... nor cal bob
Old Dec 26, 2010 | 03:02 AM
meatchief's Avatar
meatchief is an unknown quantity at this point
Default Me too
I have same issue, 2004 also, started today, was driving on hiway here in cold Minnesota, dash indicator said 2hi, i drive OK for about 20 miles w/cruise control on at 65mph. As soon as I disengaged the cruise to slow down to turn off the hiway, started to howl, sounded like near passenger side front tire, howling got lounder as I got slower. I put in 4hi and the noise immediately went away. I had to cycle between 2hi/4hi a few times, back up, turn a figure 8, finally noise went away. However, on return trip back home tonight, same exact thing- drove for 20 miles @ 65mph in what I thought was 2hi- didnt seem like blazer was in 4wd- when I slowed to turn off freeway again, holing started, got real loud as I slower. Monkeyed around with cycling between 2hi/4i, backed up, figure 8, etc, and seems to have gone away. Someone rebulit my transfer case last week, and I have spotty issues since. I want to see if the cable is sticking tomorrow- my thought is to spray penetrating oil into both ends- my question to the forum: how hard is it to remove the end that attaches to front differential- I dont want to start messing with the protective boot before knowing of the boot pulls off, twists, off, and how can I disconnect and reconnect the cable?
Thank-you and Happy Holidays to all!
Old Dec 26, 2010 | 08:46 AM
You have to remove the 3 bolts that hold it on at the front differential.
MTopper
Jul 12, 2011 12:19 AM
lionel2
Apr 16, 2008 04:45 PM
Chev it or leave it
Nov 22, 2006 10:08 AM
vol
Oct 30, 2006 12:10 AM
white04blazr
Suspension Tech
Oct 5, 2005 11:06 PM
