2wd / 4wd knuckles 2000 ls
Old Feb 12, 2026 | 08:31 AM
Lincoln9's Avatar
Lincoln9 is on a distinguished road
Default 2wd / 4wd knuckles 2000 ls
I had a hub bearing fail recently. After replacing hub, rotors, and pads, the caliper bracket is making contact with the rotor. I thought it was the caliper bracket. Put one on and still have the same issue. I can see the the ears on the knuckle are bent just a little causing the issue. Not much luck finding a 2wd knuckle locally. The blazer has over 300k on and dont really wanna dump a ton of cash in this thing. The picture shows the gap tighter on the one side of the bolt as opposed to the other. When i tighten the bracket bolt, it pulls the top of the bracket in and causes it to make contact in the area where the pads goi in the bracket. Are the 4wd knuckles the same.with the exception of the hole for yhe axle to pass through?
Andrew11
Feb 23, 2023 07:28 AM
RTJ49
Apr 25, 2018 01:32 PM
eaglei22
Dec 23, 2015 06:52 PM
MVPalmer271
Dec 30, 2007 12:41 AM
Blazin 4x4
Oct 17, 2005 04:55 PM
