Brake Pad Bracket Rubbing on Rotors Ouch!
Old Dec 28, 2007 | 10:59 PM
MVPalmer271's Avatar
MVPalmer271 is an unknown quantity at this point
Default Brake Pad Bracket Rubbing on Rotors Ouch!
OK, I just finished reassembling my blazer after replacing the lower ball joints. Drivers side flawless, on the passengers side the bracket for the brake pads is rubbing the outside of the rotor. The hub appears to be runnung true and I used torque wrenches so i dont think i bent anything. Unless my hub is not properly seated in the (Excuese terminology) bracket that the tie rod end and stabilizer connect to? Any ideas thanks.
Old Dec 29, 2007 | 03:25 AM
Chevy Lover's Avatar
Default RE: Brake Pad Bracket Rubbing on Rotors Ouch!
Either the hub is not is not properly seated or the caliper mounting bracket is not flush with it's mounting surface.
Measure the distance from the axle nut to the end of the axle on both sides and compare. This may give you an idea if the hub is not fully seated.
[IMG]local://upfiles/2910/861E5B23FF4D408DAA3E81399B89C1AE.gif[/IMG]
Old Dec 30, 2007 | 12:03 AM
Thanks, that was it, the hub wasnt seated prroperly. I guess i didn't get the big, thick, goofy gasket back in corectly and it held it out just enough.
Thanks again
Michael
Old Dec 30, 2007 | 12:41 AM
Excellent, glad you got it fixed.
datmanj
Feb 5, 2013 12:11 PM
chris015
Aug 9, 2011 10:41 PM
oktain
Jun 10, 2010 03:53 PM
flyinbrad
Sep 28, 2007 02:21 PM
Acer2428
Jul 13, 2006 11:52 PM
