2wd vs 4wd rear axle width?
Old Sep 3, 2009 | 08:26 AM
kgkern01's Avatar
kgkern01 is an unknown quantity at this point
Default 2wd vs 4wd rear axle width?
Is the 2wd axle narrower than the 4wd axle? I am wondering because the 2wd wheels have what, 2" less backspacing but still seem to tuck up under the body as much as the 4wd, when in theory should stick out 2" more than the 4wd if the axle is the same width.
Old Sep 11, 2009 | 08:12 AM
kgkern01's Avatar
Anyone?
Old Sep 11, 2009 | 08:24 AM
TripleBlackBlazer's Avatar
You are correct, the 2wd is 54", 4wd is 59", and ZR2 is 63".
Old Sep 12, 2009 | 07:14 AM
kgkern01's Avatar
So then putting some 2wd wheels on our 4wd would help fix the 'tucked-in' look of the rear end that our trucks have? Does anyone have any pics of 2wd wheels on a 4wd Blazer?
Old Sep 12, 2009 | 07:57 AM
You have to be careful with backspacing since 2wd are 4-4.5" of backspacing. This puts extra wear on the wheel bearings and might cause you to rub, either on your fender or frame.
You can either get a ZR2 rear and use the same 4wd rims ($$$) or get spacers for the rear ($).
Putting 2wd rims will push the wheel out further, but in the front AND the back, so you will still have a 'tucked' look.
BlazerRaider
Feb 21, 2019 01:09 PM
brunosrk
Tires and Wheels
Jul 3, 2011 10:06 PM
tony991
Tires and Wheels
Jun 24, 2010 11:55 AM
robbiegamble
Feb 14, 2009 12:20 PM
Likwid
Tires and Wheels
Apr 3, 2006 03:50 PM
