4:10-4:11 gears
All I know from your post is that you have an '85 4WD blazer.
I would suggest that you ask the partsman at your local dealership to tell you what you have. You'll have to give him the RPO code that should be in your glove box or the VIN#
If you are planning on changing the gear ratio you will neen to do both the front and rear differentials the same.
