4.10 or 4.56
Old Mar 14, 2010 | 10:12 PM
tony991's Avatar
tony991 is on a distinguished road
you do realize that both diff's need to be the same ratio, right?
Oh ya i know. I can change the gears in the back diff any time. I just want to change the gears in the front diff as i'm putting in the lift so i won't have to take everything apart again. I'll just keep it in 2wd until i change the gears in the rear diff.
Originally Posted by abig84
i was gonna say if it was a fullsize blazer with no over drive 410s or even 373s. im running 410s on my k30 with 33s and it kinda sucks on the highway. but with that 2.8 you might need the little boost.
i had a 85 with a 2.8 and 33s i ran for a few years but the engine was f'ed up. only ran on 5cyl so i really cant give a testimonial to how good it ran on the road.
whats in it now?
I don't know what the gear ratio is right now though.
And i can't see what the normal rpms are at driving speed cause i don't have it registered right now. And plus it has no brakes..
Old Mar 14, 2010 | 11:18 PM
LuvMyTJ's Avatar
I'm gonna say the 4.56 Thats what I run in my Jeep with 33's
Feels like stock tire size, but yur gonna lose a little in the MPG's.
I also wouldn't recommend only doing the front and driving in 2WD... bad idea.
Old Mar 15, 2010 | 04:55 PM
tony991's Avatar
Ya..I only drive it around the yard because its unregistered. I'm not gonna register it till i'm all done.
I know lmc truck has 4.10s, but where can i get 4.56 gears for it?
Old Mar 15, 2010 | 06:10 PM
LuvMyTJ's Avatar
I usually use Yukon Gears in my junk
http://www.yukongear.com/
Old Mar 16, 2010 | 06:45 PM
tony991's Avatar
Here's a link for 4.45 gears at summitracing...
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
What is axle model do i have?
Old Mar 16, 2010 | 08:10 PM
LuvMyTJ's Avatar
Here is a gear calculator you can use to get the correct stuff...
http://www.csgnetwork.com/gearratcalc.html
Old Mar 19, 2010 | 08:08 PM
tony991's Avatar
I'm gonna go with the 4.56s but i'm still confused on what the axle model is for the front and rear diffs of my 87 s10 blazer. If you click on the summitracing link you'll see a section on the left for the axle models, Is it GM 7.25" IFS, GM 8.25 IFS, GM9.25 IFS, and so on??
Old Mar 19, 2010 | 08:15 PM
You have to select the s-series blazer, not the fullsize. Most of those listed are fullsize. You have the GM 7.5 rear diff (actually 7.625).
Old Mar 19, 2010 | 08:21 PM
tony991's Avatar
ok so GM 7.5" rear diff.. Now what kind of front diff do i have??
LuvMyTJ's Avatar
Use this as a guide. Verify before you buy! Especially since this conflicts what Kyle says.
