4.11 gears?
Old Mar 5, 2012 | 01:07 PM
collinb1234's Avatar
collinb1234 is on a distinguished road
Default 4.11 gears?
I have a 2000 gmc jimmy 4 dr and if I want to regear my truck for 32s is 4.11 gears ok? I think I have 3.43 if I remember right. Will 4.11 gears give me horid mpg? Any pros or cons? And will I need two sets of these these?
http://www.justdifferentials.com/index.php?main_page=product_info&cPath=22_31_75&pr oducts_id=3226
And is regearing a diy job? Or should a shop do it? Thanks
Old Mar 5, 2012 | 05:53 PM
AJBert's Avatar
Those would be the perfect gears for 32's. MPG shouldn't be affected too much from what you got stock. If you have a 4wd, you need to change the gears front and rear.
And if you have to ask if this is a DIY job, have a shop do the job.
Old Mar 5, 2012 | 06:50 PM
tibby's Avatar
Default .
Not to thread jack, but what do parts and labor cost on replacing gears for my 4x4?
I have 3.43 and would like 3.73.
Old Mar 5, 2012 | 06:57 PM
warthogdriver's Avatar
My local shops say between 200 and 300 if i supply the parts.
gears and master bearing kit per axle.
Old Mar 5, 2012 | 07:02 PM
tibby's Avatar
Default .
Okay, now I just need to find out how much some 3.73 gears in good condition would run. Because this is definitely an install I wouldn't want to attempt right now lol.
Old Mar 5, 2012 | 07:14 PM
I bought some 3.73 gears and a trac loc for my stang on ebay for 200
Master bearing kit was 75.00 from american muscle.
now granted that is all for a mustang...but gives you a good idea.
I wish i knew how to do the swap and rebuild myself...wouldnt even know how to start.
Old Mar 5, 2012 | 08:48 PM
AJBert's Avatar
The rear axle, labor wise, isn't bad as they can do it by just dropping the cover.
The front? Quite a bit more as they have to drop the front diff because it is a spit casing.
I haven't priced it but most I've seen are around $800-1000 for labor only.
James1965
Jan 16, 2012 11:32 AM
76BadSign442
Feb 4, 2007 08:56 PM
97blz4x4
Jan 22, 2007 04:16 PM
DS01blazer
Headers, Intake, & Exhaust
Oct 23, 2006 02:52 AM
timetoblaze
Sep 25, 2004 01:11 PM
