4 wheel drive cable
Old Jan 2, 2009 | 10:27 PM
kattie0002's Avatar
kattie0002 is an unknown quantity at this point
Default 4 wheel drive cable
The 4 wheel drive cable jumps and chatters and moves up and down ,when you turn the wheels . The vacuum actuator was all the way out ,when the cable was un hooked it sucked in real fast ,now we can not move the cable ,would the cable be froze ? This is a 2000 S10 Blazer 4x4 everything is auto on it , it has been sitting for 2 1/2 years .
We are going to take the vacuum actuator cable outtoday ,this is connected to the output shaft tube flange ,any ideals on this ?
Old Jan 3, 2009 | 08:38 AM
Default RE: 4 wheel drive cable
It is very likely that the cable is froze. Can you move the cable by hand?
Old Jan 3, 2009 | 09:09 AM
kattie0002's Avatar
No cable does not move
Old Jan 3, 2009 | 09:11 AM
That would be my first guess is a froze up cable. If you can get some spray lubricant onto the cable and start to work some movement into it, you should be able to get it freed up. If not, then you will have to replace it.
Old Jan 3, 2009 | 09:14 AM
kattie0002's Avatar
Could it be a chance that any of the gears could be stripped out ,we do not know how long it was drove with the cable froze,
Old Jan 3, 2009 | 09:19 AM
kattie0002's Avatar
The indicator switch was undone not plugged in can not firgure out how it plugs back in , do you think maybe something have slip down into this .
Old Jan 3, 2009 | 04:42 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
The only thing that frozen cable did was keep the front drive axle spinning the transfer case. No gears to strip. No dammage. Poor gas milage. But no dammage.
Old Jan 3, 2009 | 08:24 PM
kattie0002's Avatar
Oil the cable really good than we change vacuum hose replace change the vacuum value other was locked ,evrything seems to working really good so far keep my firgers crossed and thank you swartlkkand the forum information you guys have on here
mirrorimij
Jun 8, 2019 03:34 PM
TexasRider
May 30, 2013 09:10 AM
Squad-6
Apr 22, 2013 02:19 PM
lizzj70
Jun 23, 2010 06:57 PM
blazerduo
Dec 17, 2009 10:54 AM
