4WD center link part number question
Old May 7, 2009 | 01:36 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default 4WD center link part number question
Hi All
They told me I had to replace center link in my Blazer. I try to find it at Rock Auto or to find part number on AC Delco site but I can find only 2WD or RWD (I think 2WD=RWD). Where could I find center link for 4WD? What is the problem with it? Any idea?
Regards, Marcin
Old May 7, 2009 | 03:21 PM
I show two part numbers that are not associated with the ZR2 package.
26055302 - w/ offroad package (RPO ZM6?)
26038980 - w/ smooth ride suspension (RPO Z85?)
However, that is just some of the descriptions that pop up on GMPartsDirect.com... You should contact a dealer with your VIN for proper identification of the part number you require.
Old May 7, 2009 | 03:24 PM
Marcin's Avatar
Thanks. I am not sure if they are right and I should chnge it. As I can see there is no any ball-joints in this center link - it seems to be a kind of metal link so why to change it? For 2WD it is differet - center link comes with 2 ball joints.
Regards, Marcin
Old May 7, 2009 | 03:36 PM
VERY odd that they would want to change it. The only reason would be that there is a problem with one of the tapered holes which the inner tie rod ends and the pitman/idler arms fit into.
Old May 11, 2009 | 12:43 PM
Marcin's Avatar
You were right. I have to change idler arm not center link.
Marcin
spider21
Nov 17, 2011 06:27 PM
ChevyHick01
Jun 18, 2011 06:27 AM
canecbr600
Sep 4, 2010 09:15 PM
monti72
Jun 19, 2010 05:06 AM
doodad69
Dec 1, 2008 01:44 PM
