4wd issue
Old Jan 26, 2011 | 05:45 PM
dreadinger's Avatar
dreadinger is on a distinguished road
Default 4wd issue
I just bought a 1995 blazer 4wd and once in 4wd it is difficult to get back in 2wd. I can herar the clicking under the dash when I push any of the buttons, When I push the 2wd button most of the time it stays in 4wd high, any help will be appreciated.
Old Jan 26, 2011 | 06:00 PM
Does it help to be moving a bit?
Old Jan 26, 2011 | 06:09 PM
dreadinger's Avatar
no, tried it on the fly at different speeds and sitting still. It did it the first day when I bought it but I was able to get it back into 2hi while sitting at a light. Tried 4wd again tonight but it now it won't go back. Also I should note that none of the 4wd lights are working.
Old Jan 26, 2011 | 06:38 PM
You may have to get the front axle up in the air and see if you can spin the front driveshaft after someone presses the 2HI button.
Can you easily shift from 4HI to 4LO?
Old Jan 26, 2011 | 08:02 PM
dreadinger's Avatar
yes, no problem there
Old Jan 26, 2011 | 09:16 PM
It is possible that you have the same problem I just repaired in my uncle's '99 Sonoma with the NV233 transfer case.
That's the inside of the encoder motor on the transfer case. His condition was very similar to yours in that it would shift from 4HI to 4LO just fine, but would not shift to 2HI.
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
USMarine1108
Oct 18, 2009 09:47 PM
