4wd light blinking constantly.
Old Jan 9, 2015 | 07:10 AM
Bolbol's Avatar
Bolbol is on a distinguished road
Well i tried in park and it didn't engage.
It's still kinda buggy five mins ago I checked again and the 4wd high wasn't working either. When it does I'll try low on neutral
Old Jan 9, 2015 | 08:11 AM
It often helps to be slightly rolling with the trans in neutral when trying to do a range shift (hi to lo or lo to hi).
Old Jul 31, 2015 | 10:51 AM
TMM217's Avatar
TMM217 is on a distinguished road
Just wanted to chime in and say thanks for all the great repair info. I have the 4 button and was having issue with axle locking into 4hi. I first checked cable at actuator to see if it would move by hand, which it did, then I checked vacuum hose there and found no vacuum with 4hi light blinking. I then came here and found out that I did not have the 3 port vacuum switch on the TC which I thought might be the problem. Long story short, found vacuum line at solenoid had broken off. I cut line flush reattached and my problem is fixed.
Old Aug 12, 2015 | 01:47 AM
Barnard22's Avatar
Barnard22 is on a distinguished road
Could be several things.
Need to have the codes pulled. You'll need a scanner capable of pulling Ford-specific codes. Don't know if the cheapos will work, but it's worth a stop at AutoZone.
ctyclkr
Jul 8, 2015 06:22 PM
Mike_Williams7
Feb 10, 2015 07:29 AM
ttwo
Oct 28, 2010 12:35 PM
xderkax
Jan 14, 2010 11:38 PM
pigmak
Jun 25, 2009 06:12 PM
