4x4 not working
4x4 not working
hi everybody i have 1999 blazer w/ 4 button switch. I hear the TCM Switch at start up and when i push the button 4 auto, 4 hi, or 4 lo. I can also hear the fron axle click in but the switch just flashes. I checked the acutulator under the battery tray and it seems to have vacuum. I dont know what else tyo check cause i cant afford to take it somewhere. Any help would be appreciated.
thanks
thanks
RE: 4x4 not working
Given that you have the Auto4wd system, you have your work cut out for you. You can test the switch in the dash by following the information in THIS POST. RSGear.com has a few articles on the NV246 which is the big brother to the NV236 which is used in your truck. And there are many other active threads which you can read through and try to pull appropriate trouble shooting steps from.
mjw1991
02-24-2013 10:18 PM
blazer9893
06-07-2011 04:21 PM
bootlegger
12-14-2010 05:18 PM
218persuader
08-20-2010 06:11 PM
