4x4 not working
4x4 not working
So we had about a foot of snow today and wanted to test out the 4x4 (havent had a chance to try it out yet) So me and another fourm member (86Blazer4x4) head up to a school, put it in 4 hi and do some drifting. He does a few good ones then I get behind the wheel and do one and get somewhat stuck. Go to get out and only the back tires are spining, the fronts are just sitting there, relaxing, being lazy. But anyway, on the 4x4 selector is working fine but its just not shifting in. Any ideas on what to check? Also heres a video of me getting stuck
http://www.youtube.com/watch?v=3j5A6Y4Pmcw
RE: 4x4 not working
Check to make sure the actuator cable is not frozen,
checking to make the actuator is not broken,
check the vaccum is holding from the switch on the transfer case,
make sure all your vac lines are hooked up,
if everything else is fine then your vac switch on the transfer case might of failed. when you do the selector do you hear a click noise from the passenger kick panel?
RE: 4x4 not working
got it. The vac line wasn't plugged in and it had huge cut on it, barley held together. replaced the line, everything working fine now. thanks!
RE: 4x4 not working
Great, glad to hear.
RE: 4x4 not working
flattop??? how did you this out..... Status: Running at 89% operational capacity
RE: 4x4 not working
we tested it out by taking it through the snow. or are you talking about the 89% operational capacity?
Must just mean that there are other gremlins to work out...
mjw1991
02-24-2013 10:18 PM
blazer9893
06-07-2011 04:21 PM
bootlegger
12-14-2010 05:18 PM
218persuader
08-20-2010 06:11 PM
