4x4 problem PLS HELP
Old Feb 10, 2014 | 09:43 PM
03blazerchick's Avatar
03blazerchick is on a distinguished road
Default 4x4 problem PLS HELP
Okay here's my issue it started a week ago I got stuck in my yard and I engaged my 4hi and heard the transfer case click I went to drive out and only my rear tires would spin and the front wouldn't so I tried 4lo and the same issue.... so I took it to my friends house put it on the lift and checked the front drive shaft to make sure it and spinning and it was. So I figured tge front axle actuator so I took off the battery and checked my actuator it seemed stuck a little and I unstuck it and it seemed to be leaking something so I put the battery back on thinking I needed a new actuator and I put it in 4hi ran fine heard the xfercase click then I put the truck in drive and it just stalls out. It didn't do that before I need help I'm going to change the actuator I just want expert opinions please much appreciated pls n thank you (:
Old Feb 11, 2014 | 11:12 PM
Thogert's Avatar
**Moved to Steering, Suspension, and Drivetrain**
03blazerchick
Feb 11, 2014 09:58 PM
scprosportsman
Tires and Wheels
May 29, 2011 05:39 AM
PhillyZ
Oct 6, 2009 02:10 AM
tyrant46whtcobra
Sep 7, 2008 08:00 PM
nitrous2126
Nov 7, 2007 01:59 PM
