4x4 to ZR2 ?
Old Oct 21, 2007 | 12:16 PM
willjones's Avatar
Default 4x4 to ZR2 ?
Is it possible to take a standard 2d 4x4 and take the suspenison off of a ZR2 and swap it over to get more lift? If so what parts need to be transfered and what mods have to be made?
Old Oct 21, 2007 | 12:22 PM
Default RE: 4x4 to ZR2 ?
Not possible unless you swap your body onto a ZR2 frame. Completely different frame between the two.
Old Oct 21, 2007 | 05:06 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
i wish it was an easy switch because i would have done it the day i brought mine home. i even looked in to swapping and s10 body onto mine.
Old Oct 21, 2007 | 09:40 PM
Mapoftazifosho's Avatar
Mapoftazifosho is an unknown quantity at this point
ORIGINAL: swartlkk
Can your provide some substantion of this because that sounds like the dumbest production flaw I have ever heard off...[sm=badidea.gif]
Old Oct 21, 2007 | 09:49 PM
The frame under the ZR2 is completely different as are the upper and lower control arms and their mounts. The frame itself is stronger than the stock frame. Not a production flaw as you see it, but more of a marketting promotion.
I'm sure Jigg can explain in more detail than I am able to.
Old Oct 21, 2007 | 09:50 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
The reason why it is different is because of the way the suspension mounts to the frame and the way that the frame is made. Pretty much a ZR2 is just a blazer with a way better frame/suspension setup, made more for offroading. I am pretty sure they were made on seperate product lines and maybe even different plants.
EDIT: If you really wanted better off-road performance it would be better and cheaper to just go with the 5-6" suspension kit.
Old Oct 21, 2007 | 11:03 PM
thegr81's Avatar
hey lennyblazer the 5-6 suspension lift is that a good lift for a 4 door 4x4 im debating between either a 4 door 4x4 or a 2 dr zr2 im in debate cause im going to get either one after i pay my 2wd off in the next year
Old Oct 21, 2007 | 11:07 PM
Lets try to stay on topic here...
Old Oct 22, 2007 | 04:28 PM
willjones's Avatar
well that settles that thanks for the insight fellas
Bberry20
Feb 25, 2010 09:28 PM
Spectreblazer
Feb 13, 2010 04:59 PM
Logan
36
Dec 6, 2009 07:41 PM
PJT2007
Oct 7, 2008 10:47 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
