93 Electronic Transfer Case Issues
Old Oct 2, 2024 | 09:19 PM
DevonAkaOzzy's Avatar
DevonAkaOzzy is on a distinguished road
Default 93 Electronic Transfer Case Issues
I have a 93 4dr S10 Blazer, CPI engine with the 233 Electronic transfer case. Had issues with the encoder motor shifting the transfer case, so i replaced it. Now, it will shift into 4HI with no issues. Shifts into 4LO without a problem. However, it refuses to shift to 2wd from 4HI. it will click 3 times and stay in 4hi. Tried rolling in fwd and reverse, neutral, park, and anything in between. It will shift between 4HI and 4LO all day no issues, but it will not return to 2wd. The front axle disconnect works fine. I did manage to get it back into 2wd seemingly by luck after trying for 45 minutes or so. What should I look into? Try a different encoder motor? It was installed correctly (installed while in 2wd). Winter is coming up and I would like to be able to shift into and out of 4x4 for winter.
oscar73
Jul 17, 2024 09:44 AM
tycobb280
Sep 12, 2016 02:02 AM
pathfndr
Jan 1, 2011 09:14 PM
renswic
Jan 30, 2010 07:46 AM
Peco
Apr 14, 2007 12:17 AM
