Automatic Standard Transmission Swap
Old Mar 14, 2011 | 09:19 PM
mmikemitchell's Avatar
mmikemitchell is on a distinguished road
Default Automatic Standard Transmission Swap
I have a 79 Blazer 4wd with a 3 speed manual transmission. I also have a 76 chevy pickup with an automatic transmission that I can use as a doner. I would like the Blazer to be an automatic.
Can I install the automatic without too much modification>
Thanks
Mike
http://www.carburetor-parts.com
Old Mar 14, 2011 | 10:56 PM
TZFBird's Avatar
TZFBird is on a distinguished road
It would help if you specified what type of transmission it is. If it is the original in '76 it should be a TH350. I believe all those need are a vacuum signal off the engine for shift points. If it has been converted to a TH700r4 you will need the TV cable that runs up to the throttle linkage as a signal for shifting(very critical component).
In either case you would need a transmission oil cooler (a standalone that goes in front of the radiator is fine), as well as a cable and shifter.
More than likely the cross member will mount in a different point for the automatic vs. the manual so be prepared for some modification there as well. Of course the transmission can come with electrical or cable driven speedometers, so that is something you will need to account for as well.
Since it's a 4x4, you'll also need to look into the differences in transfer cases. They are close enough that the bolt patterns would probably be the same.
SteveOO
Jul 16, 2010 10:42 AM
jstein
Jan 29, 2010 12:59 AM
old skool luvr
Nov 28, 2009 10:18 PM
trhull
Sep 6, 2009 10:49 PM
OldJr88
Aug 13, 2009 12:13 AM
