96 blazer transfer case fluid question
Old Dec 2, 2010 | 06:23 PM
LowLife's Avatar
LowLife is on a distinguished road
Question 96 blazer transfer case fluid question
well i was reading that im supposed to fill her up with Dexron III, just wanna be sure before i fill her with the wrong crap. Oh and anyone know the full capacity i dont wanna be a quart short or anything when i go to fill her up. and also does anyone know what tip i need to remove the drain and filler bolts on the case a t50 or a? not so sure on that part, thanks ahead of time for your help guys
Old Dec 2, 2010 | 08:31 PM
Same stuff you put in the transmission for the NV233 (3-button) transfer case.
Should be just over 1qt so have two on hand.
The drain & fill plugs are not torx, but they are allen head. I can't remember the size though.
Old Dec 2, 2010 | 10:52 PM
LowLife's Avatar
Wink
Thanks swart, You always come thru in the clutch . But now i have been runnin b&m trick shift "the blue stuff" in my blazer & jimmy....should i use that, Or should i go with the Dexron III like they called for, Also would a little lucas be good for it since the capacity is just over 1qt maybe like a 1/4th of a qt of the lucas, Sorry for the 21 questions brother, But in pa the snow is comin and i dont wanna be left out in the cold if you know what i mean. Oh and by the way i wanted to let you know i pulled the upper intake off last night to change my oil pressure sensor, And switched the stock injector bracket over to the mpfi bracket while i was in there since it was recommended by you, I figured for $31 bucks it would be worth it just to be on the safe side.
Old Dec 3, 2010 | 09:54 AM
It really doesn't matter so long as it meets the Dexron III or higher requirements.
Old Dec 3, 2010 | 02:52 PM
LowLife's Avatar
Alright thanks for the help, Im gonna go get that takin care of today
Old Dec 4, 2010 | 09:43 PM
LowLife's Avatar
Well i drained out my old transfer case fluid today, The drain plugs are a 30mm head bolt for the drain & filler plugs. My old fluid was black, I used a hand oiler pump to spray in the new fluid since there is no chance of ever using a funnel or hose or bottle buddy or anything else i could come up with. Just thought this post my be informative to anyone looking to change there transfer case fluid as well. Oh and i used valvoline dexron iii high mile atf.
Old Dec 6, 2010 | 11:45 AM
Tinted's Avatar
Tinted is on a distinguished road
how often should this fluid be changed?
any diagram showing how/where to drain and replace?
Old Dec 6, 2010 | 12:24 PM
Depends.. Check your owners manual for direction on service intervals.
Just look on the back of the transfer case. You will see two plugs positioned almost directly above/below each other.
Flyfishen
Jun 18, 2019 11:22 AM
kyle123
May 15, 2010 10:34 AM
Brianator99
Aug 30, 2009 06:18 PM
whoareyou4
Aug 12, 2009 03:12 PM
DaleA
Jan 13, 2009 08:50 PM
