99 blazer clicks when turning in 4x4 only, already replaced CVs
Old Jan 14, 2010 | 06:22 PM
MetalMan390's Avatar
MetalMan390 is on a distinguished road
Default 99 blazer clicks when turning in 4x4 only, already replaced CVs
i have a 99 blazer 4x4 that clicks when turning... doesn't have to be going around corners, will click if the wheel is slightly turned while driving too. this ONLY happens in 4x4, it has no problems or noises in 2wd. i already replaced the cv axles but it did not help. my mechanic said it's likely to be a bearing in the transfer case, i forget what exactly. does this sound right? if so, is there a write-up on how to replace it?
Old Jan 17, 2010 | 06:20 PM
seems like it's a bad output shaft bearing in the transfer case. by the time i get all the necessary parts and pay someone to tear it down i figured it would be cheaper just to buy a new one, so i ordered a used transfer case with 87k miles for $140 shipped... any good write ups on how to replace it, with pictures? what are the additional parts i will need when replacing it (any gaskets, etc)?
vladcebes
Apr 6, 2012 09:39 PM
pjbassman
Aug 14, 2011 02:15 PM
bigtexk5
Jan 28, 2011 05:36 AM
GotYoNacho
Feb 24, 2009 07:41 PM
huntjock
Apr 11, 2008 02:12 PM
