Adding a stock replacment steering stabilizer to a truck built without
Old Jun 26, 2008 | 01:29 PM
ROADRAGE79's Avatar
ROADRAGE79 is an unknown quantity at this point
Default Adding a stock replacment steering stabilizer to a truck built without
I have a 98 S-10 Jimmy, 4x4. I bought replacement everything for the front suspension (except the centerlink), and they gave me a steering stabilizer. My truck wasnt equippped with one from the factory, but I would like to add it. There is a bracket on the frame for it, but I do not have the correct centerlink. I called the dealer for a price on the correct centerlink, but they need a part number. Has anyone added one, and if so, do you have a part number?
Thanks for any help.
Old Jun 26, 2008 | 02:01 PM
Default RE: Adding a stock replacment steering stabilizer to a truck built without
What does the shock look like? Does the moving end of the shock just have bushings, washers, and a nut straight off the end of the shaft or does it have a welded on 'T' on the end.
I have seen some people just make up a bracket and use u-bolts to fasten it to the centerlink.
Old Jun 26, 2008 | 02:30 PM
ROADRAGE79's Avatar
both ends are the same, just on opening for a bolt to go through. I thought about just using a u bolt or something, but I would prefer to use the right centerlink. I work in the insurance industry, and I can easily imagine some over zealous adjuster screwing me over somehow if I get into an accident.
Old Jun 26, 2008 | 04:17 PM
pbishop's Avatar
pbishop is an unknown quantity at this point
ORIGINAL: ROADRAGE79
Scarry thought, especially comming from someone who works in the industry.
Old Jun 27, 2008 | 02:52 PM
01ice's Avatar
01ice is an unknown quantity at this point
I just did one on my 01,I went to the wreckers and pickedup a center link with extra hole for stabalizer for $20,then swaped it out everything fits right together.
MrCodySir
Feb 22, 2014 02:34 PM
tony991
Dec 26, 2009 12:11 PM
noom14921992
Apr 25, 2008 09:28 PM
nj4x4blaze
Nov 18, 2007 09:28 AM
fwish21
Suspension Tech
Oct 9, 2007 05:50 AM
