torsion bar identification?
Old Jun 19, 2008 | 03:56 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
Default torsion bar identification?
i have installed 31" tires, re arched the rear leafs, but have a small problem with the torsion bars, front is saging and the adjuster bolts on the torsions are not equal, I get one set of stock one set of thicker torsion bars, the stock ones have #503 and #504 on l and r side, also found a set, which is 281L and 282R numbrs, same ends as stock ones (1,5" hexagonal) but thicker/have more meat on the body.
Thought, they would be harder or H-D ones.
I have checked the offradtechs article about the torsion bars and inspected the GM# list but there no match with the stock ones and the thick ones, what is 503-503 and 281-282 numbers on the ends? rates etc?
thanks.
Old Jun 21, 2008 | 03:39 AM
Default RE: torsion bar identification?
Since theres no info on the torsion bar identification, me and a friend of mine installed thick torsion bars and lifted the truck.
Update:
The front is stiffer now, ( just 30 miles road test way back home) .
Im not sure if this stiffness is caused by bars itself or cranking. BTW driver side key has cavitation on the adjusting bolt place, i have replaced both adjusting bolts with the longer ones.
Old Jun 26, 2008 | 09:06 PM
iroczu's Avatar
iroczu is an unknown quantity at this point
did you get anymore lift out of them??
Old Jun 27, 2008 | 04:14 AM
Yes i have cranked them 2". I had my 31" bf all terrains installed, need to crank it up.
Old Jun 27, 2008 | 05:00 PM
bad350v8s10tahoe's Avatar
bad350v8s10tahoe is an unknown quantity at this point
In general theory bigger is always better, more heavy duty
azzr2
Mar 25, 2012 04:19 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Mbastet99
Nov 7, 2006 07:52 PM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
