Alignment Question
Old Dec 8, 2010 | 01:55 PM
brooklynRick's Avatar
brooklynRick is on a distinguished road
Default Alignment Question
Hi,
I went to an alignment shop to see if they could do my truck, 82' Jimmy. The problem is that is has a 3" lift and I bought it that way but the shop said the needed the specific alignment data for that lift so they could not do it. I'm not sure where to even start looking for that info, how can I find the maker of the lift parts, would there something be stamped on a specific part i can google?
Thanks
Rick
Old Dec 8, 2010 | 04:05 PM
84BlazerS10's Avatar
I've never heard of that but then again i've never tried an alignment on a lifted car. But, there should be a brand name stamped somewhere on the lift kit just not sure where it would be but I would assume it would depend on the brand.
Old Dec 8, 2010 | 09:48 PM
franklin's Avatar
franklin is on a distinguished road
I never heard of that before either. yes adding a suspension lift to your vehicle does change your alignment angles, but when having an alignment performed on your vehicle it should be set back to factory settings. you can raise your car up 20 inches, but you should still have your camber, caster and toe settings set back to factory.
Old Dec 9, 2010 | 07:01 AM
Originally Posted by franklin
i never heard of that before either. Yes adding a suspension lift to your vehicle does change your alignment angles, but when having an alignment performed on your vehicle it should be set back to factory settings. You can raise your car up 20 inches, but you should still have your camber, caster and toe settings set back to factory.
^^this^^
blazen_red_4x4
Oct 13, 2014 12:39 PM
ZR2KID22
Nov 23, 2012 08:10 AM
litterbug
Jul 19, 2011 10:46 AM
jsmz
Jul 16, 2009 04:38 PM
ClueMeIn1989
May 19, 2009 08:38 PM
