Bilstein Shocks don't fit right on 96 Blazer 4WD LT
Old Dec 24, 2013 | 12:22 PM
mdmccurr's Avatar
mdmccurr is an unknown quantity at this point
Default Bilstein Shocks don't fit right on 96 Blazer 4WD LT
Hello Everyone,
I am working on a 96 Blazer 4WD LT, with Torsion Bar front suspension. Everything is factory stock and I have owned the truck since new.
I am replacing the front Bilstein shocks. I am removing "Sport" version (P/N f4-B46-1413-HO) and putting on the standard HD version (P/N 24-187831). According to the Bilstein catalog, both should work for my truck, the Sport is just a little bit firmer ride.
The upper and lower metal sleeve (that the shock bolts go thru) is too big to fit the suspension. I measure the hardware on the old shock at 41.29mm and the new shock is 42.38mm......that's 1mm too wide to fit the mounting brackets on my truck.
I guess I could grind the metal sleeve on the new shocks down to size but it's hard to believe that Bilstein's catalog is wrong and their shocks don't fit. Has anyone else had trouble with shocks fitting the brackets on the Blazer?
Bilstein customer service is closed for the holiday until January....any ideas?
Thanks
Old Dec 24, 2013 | 01:55 PM
newguy's Avatar
I think mine where tight but not that much. Think I persuaded them with a BFH
Old Dec 24, 2013 | 11:48 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
I was about to say BFH or a grinder will make em fit.
Old Dec 25, 2013 | 12:54 AM
2000BlackBeauty's Avatar
2000BlackBeauty is on a distinguished road
I just installed Bilstein shocks (front/rear) on my Blazer that I bought off Ebay .... Didn't have any issues putting them on ... it might be worth the wait to call Customer Service to see if they sent you the correct ones before you go pounding away or grinding things up on your ride ... just my .02cents
Old Dec 25, 2013 | 04:25 AM
newguy's Avatar
I`m also thinking someone else may have had smaller ones in there and torqued the nut and bolt pinching the slot closed a bit
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
98Ltblazer
Sep 7, 2010 06:08 PM
vze4yrte
Sep 1, 2010 08:19 PM
pewter00blazer
Apr 7, 2009 07:32 PM
cain45
Nov 21, 2007 12:33 PM
