Blazer crew, I need help. 4x4 problem
#21
RE: Blazer crew, I need help. 4x4 problem
Should be fairly close...
Drive up on blocks, it'll be eaiser to see underneath...
#22
no blocks.......but I'll use the curb
#23
lol, well, if you can find a Neon that looks like it hasn't been moved in awhile...
#24
LOL! my cousin!!!!!
he has a 00 neon and I think he's a little jealous of my Jimmy [8D]
#25
lol!
He won't notice the tire tracks... *smiles innocently*
#26
ORIGINAL: 20Blazer00
Here is a picture of the front differential vacuum actuator diaphram:
[IMG]local://upfiles/1127/482CCDF5DD714FF9AF6F05C2680B5C74.gif[/IMG]
[IMG]local://upfiles/1127/B98922554B99411991BE75CA9800B03D.gif[/IMG]
If you bumped it hard enough to knock out the bumper, I would check this and the line to the front axle (to lock/unlock the axle). I tore mine down again to do some more front end work. So I can take pictures of what I can for you and post them.
You also might want to check the vacumme check ball, if you slammed it hard enough, you might have cracked that. That is on the drivers side and is just a ball(6" dia)with one or two vacumme lines attached to it.
If your encoded motor you can hear clicking, I don't think it would be bad. Most of the time if these are bad, they wont click, there willbe just nothing at all. You also will want to check the plug to the actuator diaphram. And trace the line from there also to the front axle.
#27
arrrgghhhhh.....i wish i never hit that stupid bank [:@]
or i wish i knew what i was doing.
thanks for the info all....at least i have a click
Katmandu
11-13-2013 09:08 AM
Recon
33
01-07-2012 11:23 PM
Dhg1147
10-27-2010 05:43 PM
