Blazer crew, I need help. 4x4 problem
Old Mar 3, 2007 | 08:56 PM
  #21
drperry's Avatar
Default RE: Blazer crew, I need help. 4x4 problem
Should be fairly close...
Drive up on blocks, it'll be eaiser to see underneath...
Old Mar 4, 2007 | 12:50 PM
  #22
blazinloud's Avatar
no blocks.......but I'll use the curb
Old Mar 4, 2007 | 12:54 PM
  #23
drperry's Avatar
lol, well, if you can find a Neon that looks like it hasn't been moved in awhile...
Old Mar 4, 2007 | 12:56 PM
  #24
blazinloud's Avatar
LOL! my cousin!!!!!
he has a 00 neon and I think he's a little jealous of my Jimmy [8D]
Old Mar 4, 2007 | 01:15 PM
  #25
drperry's Avatar
lol!
He won't notice the tire tracks... *smiles innocently*
Old Mar 4, 2007 | 01:19 PM
  #26
MNHawk's Avatar
MNHawk is an unknown quantity at this point
ORIGINAL: 20Blazer00
Here is a picture of the front differential vacuum actuator diaphram:
[IMG]local://upfiles/1127/482CCDF5DD714FF9AF6F05C2680B5C74.gif[/IMG]
[IMG]local://upfiles/1127/B98922554B99411991BE75CA9800B03D.gif[/IMG]
This part is under the battery tray. And yes, its easier to get to if you do remove the battery and tray.
If you bumped it hard enough to knock out the bumper, I would check this and the line to the front axle (to lock/unlock the axle). I tore mine down again to do some more front end work. So I can take pictures of what I can for you and post them.
You also might want to check the vacumme check ball, if you slammed it hard enough, you might have cracked that. That is on the drivers side and is just a ball(6" dia)with one or two vacumme lines attached to it.
If your encoded motor you can hear clicking, I don't think it would be bad. Most of the time if these are bad, they wont click, there willbe just nothing at all. You also will want to check the plug to the actuator diaphram. And trace the line from there also to the front axle.
Old Mar 4, 2007 | 03:25 PM
  #27
blazinloud's Avatar
arrrgghhhhh.....i wish i never hit that stupid bank [:@]
or i wish i knew what i was doing.
thanks for the info all....at least i have a click
Katmandu
Nov 13, 2013 09:08 AM
rexazz2
Feb 12, 2013 08:58 PM
Recon
33
Jan 7, 2012 11:23 PM
packofqtips
Nov 21, 2010 11:24 PM
Dhg1147
Oct 27, 2010 05:43 PM
