Bolt Won't Budge
Old Dec 18, 2009 | 06:22 PM
fotijerina's Avatar
fotijerina is on a distinguished road
Unhappy Bolt Won't Budge
I have a 76 Blazer. I'm trying to replace the steering damper and I can't get the bolt on the steering linkage to budge. The nut comes off with ease, but the thing won't move. I've tried backing my wrench with a floor jack and heating it up. Please help.
Old Dec 18, 2009 | 06:58 PM
Does it spin?
Old Dec 18, 2009 | 07:08 PM
fotijerina's Avatar
I think it's the original shock. There's a 3/4" nut built onto the bolt, it then goes through the linkage and is ended with a nut. The nut comes off with ease. It wont spin or move. I backed my wrench with my floor jack and almost had the tire coming off the ground. It just won't break loose (turn/spin).
Old Dec 18, 2009 | 09:38 PM
Here is what this area looks like on my '74:
Remove the nut on the opposite side of the shock (the nut on the left of the second image above) and the shock will slide right off.
If you remove the nut directly on the steering linkage (the one on the right), you will have to fight with the tapered press fit between the shock mounting stud and the steering linkage.
Old Dec 18, 2009 | 11:18 PM
fotijerina's Avatar
On the old assembly, there is no nut on the other side just a rounded head that is permanently attached. There is on the replacement.
Old Dec 29, 2009 | 06:50 PM
fotijerina's Avatar
I finally used a pitman arm puller to get the bolt out.
Old Dec 29, 2009 | 06:53 PM
Glad you finally got it. Someone screwed with yours though or they changed things between '74 and '76. My parts manual shows a nut on both sides just like is shown in the pictures I provided.
er0ck273
Jul 4, 2013 01:36 PM
xtrmblazn01
17
Apr 11, 2012 11:32 PM
luvit
Mar 28, 2012 06:43 AM
g_mike
Sep 2, 2010 08:50 PM
ant2297
Dec 18, 2008 04:56 PM
