Brake problem
I have a 98 Chevy Blazer and just replaced the rear main line to the rear disc, and then found another leak in the front and replaced it also. After replacing them and bleeding them for about 2 hours i am still dealing with a lot of pedal travel and it at my wits end with it. If there is anybody that could give some pointers that would be great.
First I would check all my new fittings ,lines and search for dripping fluid or sign of leaking threw out all lines(sure you probably did). Did you run reservoir dry? You may have to bleed reservoir of air it may have also gone bad you can pull vacuum line off brake booster, if wet its bad for sure. Is it actually shooting fluid when your bleeding the lines? If you hear air from a certain bleeder check that line.
First thing to do is top the master cylinder up and gently tap the brake pedal. Don't push it down, just tap it with 1/2 an inch or so of pedal travel. If there's air in the lines inside the master cylinder, they will jiggle and bubble out. DO NOT stomp the pedal. It will cause highly corrosive brake fluid to blow up and out.
If you aren't using a bottle to flush the system, try it. Get several feet of tubing that will fit snugly over the opening of the bleeder. Run it down to a half full bottle of brake fluid. It like YooHoo bottles. They are clear (easy to see through) glass (isn't affected by brake fluid) and you have to drink the YooHoo to get a fresh bottle to rinse and use (Yum!). Open the bleeder and gently pump the brake pedal to the floor and let it up gently. This allows the air out while not letting more in. Keep the master cylinder full and drain the used fluid when it fills the bottle up. Bleed all four wheels. Brake fluid is hygroscopic and will absorb moisture from the atmosphere. Fully flushing it will give you a solid pedal and brakes less prone to fading under heavy use.
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
