Bravada rear suspension?
I didnt notice much difference between my blazer and the Bravada. The ride is a bit smoother then the blazer and it sits a bit lower then the blazer. Other then that its the same thing. Only major difference is the Smart Trak AWD system on the Bravada.
Heres the handling specs for both:
Bravada:
ABS
3.73:1 axle ratio
Rear differential lock
Four disc brakes including two ventilated discs
Immobilizer
Center viscous limited slip differential
Spacesaver steel rim under body spare wheel
Wishbone front suspension with stabilizer bar independent with torsion springs , beam rear suspension with stabilizer bar rigid with leaf springs
Blazer:
ABS
3.42:1 axle ratio
Four disc brakes including four ventilated discs
Immobilizer
Fullsize steel rim under body spare wheel
Bravada:
ABS
3.73:1 axle ratio
Immobilizer
Blazer:
ABS
3.42:1 axle ratio
Immobilizer
tracedumashsog
Jul 19, 2014 01:04 PM
Kadre
Sep 18, 2012 10:34 AM
Bad Ramer Jamer
Sep 19, 2008 05:43 PM
speeddemon560
Jan 11, 2007 10:13 PM
