Can I get posi lock with 4 button 4wd
Old Jan 2, 2014 | 06:24 PM
Yes. Since the TCCM is looking for the axle to lock and unlock, it would react the same way if the sensor was not opening up properly as would happen when a jumper was inserted.
If a posi-lock setup was to be attempted on a 4-button (NV236) transfer case, you would need to engage and disengage the front axle just after pushing the button on the dash. Failure to do so could cause the TCCM to lockout shifting causing you to be stuck in whatever mode/range it was in at the time of the fault recognition.
Old Jan 2, 2014 | 06:35 PM
Yup, ^^^ what Kyle said
Old Jan 3, 2014 | 03:45 AM
joshn444's Avatar
joshn444 is on a distinguished road
So I wouldn't be able to use the 2 low the posi lock would add?
Old Jan 3, 2014 | 02:55 PM
You may be able to disengage the front axle, but the TCCM might not like it and refuse to shift out of low range. It all depends on whether the TCCM monitors the switch at any other time but during shifts.
mysons95
56
Nov 18, 2021 09:35 PM
rdhack
26
Aug 6, 2011 08:21 PM
smokey94
Jan 16, 2010 10:44 AM
jimhens82
Oct 31, 2009 02:28 PM
