changed leaf springs...drivers side still lower
Old May 17, 2009 | 06:28 AM
rubeninfl's Avatar
rubeninfl is an unknown quantity at this point
Default changed leaf springs...drivers side still lower
I changed both rear leaf springs and had the shocks replaced at pepboys but the drivers side rear is still about 1 1/2- 2 inches lower than the passengers side.
What else can I do to even it out? What exactly are leaf spring helpers? Is this an option, or can I somehow lift the drivers side up the 2inches with some type of inexpensive lift kit?
Old May 17, 2009 | 07:34 AM
Were these springs new to begin with? Confirmed to be good (ie no broken leaves)? If used, did they both come out of the same vehicle? All questions I am sure you have answered in one of your other threads on this subject, but I do not have the time to read back through all of them. Really is one of the reasons for keeping everything in one thread...
Old May 17, 2009 | 04:54 PM
rubeninfl's Avatar
They weren't new, but came from a vehicle that only had 19k. They looked practically new.
Old May 17, 2009 | 05:46 PM
Confirmed to be good?
How about that measurement I asked you before...? Is your front end level now?
Also, measure from the frame to the bottom of the body to see if you have a body mount problem.
You could also measure your shackles.
If these last two measurements check out to be the same side to side and you still have a difference from the axle to the bottom of the frame (question I asked about in one of your earlier threads), the springs are the only thing that can cause it.
Old May 17, 2009 | 06:55 PM
oisinirish's Avatar
Could always swap sides and see...gotta be an easier way
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
01blazer1981
Jun 26, 2008 10:57 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
