Changing gear ratio in 8.5-10 bolt G-80
Old Jun 23, 2012 | 01:04 PM
bm167's Avatar
bm167 is on a distinguished road
Default Changing gear ratio in 8.5-10 bolt G-80
I have a rat rod with a Chevy 292, 3 speed Saginaw and a 95 Blazer 3:72 G-80 rear end. This setup is to low for highway driving/cruising. 55mph=2500rpm.
I'm thinking about changing the gear ratio to 2:73 or 3:08.
First of all, can this be done without affecting the Eaton G-80 limited slip mechanism?
Has anyone tried the above gear ratio with a 292?
Any help/ideas,suggestions would be appreciated....
Old Jun 23, 2012 | 02:13 PM
okiedoak20's Avatar
i dont see why the swap would be a problem, there is though in some cases
where the diff carrier wount fit the ring gear, that seems only going from
3.42 to somthing real low like 4.56, your gear change is not that extream,
call a gear shop to be double sure... oh, the eaton g-80 should still be usable
Wabash
Jul 21, 2013 12:09 PM
dagda
Jan 12, 2010 06:37 PM
fatsjames
Jan 1, 2010 08:49 PM
booblinker
Oct 3, 2006 12:56 PM
ceanern
Jun 17, 2006 08:44 PM
