Changing T-Case fluid, help?
Old Sep 27, 2011 | 09:31 PM
AKPerry's Avatar
AKPerry is on a distinguished road
Default Changing T-Case fluid, help?
Hey guys, had a few questions about changing my tcase fluid on my 99 blazer. From what ive seen Im assuming that the drain is on the bottom and fill is on the top. Is there a special tool to be able to get the plug out? tried a socket today and it wouldnt fit. ALSO, could bad tcase fluid be causing my 4x4 not to work??
Thank you,
AKPerry
Old Sep 27, 2011 | 09:38 PM
chris015's Avatar
Bad tcase fluid wouldnt cause it not to work,Unless its just so old and worn its chewed everything up,which i doubt. Whats the issue?
Yes fills on top,drains on bottom. Put atf dextron in it till it oozes out the top hole.. start with 2 quarts.
Old Sep 27, 2011 | 10:49 PM
AKPerry's Avatar
I didnt think so and I doubt it as well. My 4x4 is not in working order, when trying to shift to 4HI and 4LO the lights just blink, you can hear the TCCM working but no shifting underneath, I suspect the encoder motor may be the issue but also contemplating the vacuum lines. I have already changed the actuator and only ONE vacuum hose (actuator to t-case) Desperately searching for a solution
Old Sep 28, 2011 | 05:05 AM
coolasice's Avatar
coolasice will become famous soon enough
not sure about your 4x4 problem, but I changed my fluid last week, it used metric hex (allen) keys
Old Sep 28, 2011 | 06:13 AM
The type of fluid you use depends on the transfer case that is in your truck. NV233 (3 button switch on dash) takes ATF. The NV236 (4 button switch) takes GM Autotrac II fluid from the dealer; no substitutes.
Old Oct 2, 2011 | 12:02 PM
marksoftball's Avatar
marksoftball is an unknown quantity at this point
I just bought the fitting for the plug to fit on a 1/4 inch drive socket from autozone.
It was a 10mm fitting. About 4 dollars.
Mark K
Bolbol
Mar 30, 2016 03:39 PM
LannyL81
Aug 27, 2014 06:15 PM
jamextras
Oct 13, 2012 06:19 PM
DaleA
Jan 13, 2009 08:50 PM
AutomagicLS1
Engine & Internal
Dec 1, 2006 11:08 PM
