Cheap lift?
Old Oct 20, 2013 | 04:57 PM
S10BlazerFTW's Avatar
S10BlazerFTW is on a distinguished road
Default Cheap lift?
I have a 87 S10 Blazer, i just got some 32x11.5x15 i just put on. (its not roadworthy atm) I know on the rear i can get more clearance by moving the leaf springs on top of the axle, getting about 2-2.5" of lift in the rear. Now my only issue is the front. Ive seen the T-Bar Crank tutorial, and i need about 2' of lift in the front for clearance on the tires so they can turn with out hitting the wells (and without going through the hassle of trimming down the wells in the corners) And with tightening the T-Bars that much could cause problems down the road. Wanting to know if there is any other way that isnt expensive to lift the front about 2-2.5"
Old Oct 20, 2013 | 05:21 PM
newguy's Avatar
I think you may get more than 2.5 from moving the axle underneath the leafs
Old Oct 20, 2013 | 07:01 PM
warthogdriver's Avatar
^^^ yeah, that is how you get the 5" of lift in the BDS kit i put on...just swapping the axle to under the leafs will get you alot more then 2"
to get what you want cheaply you may want a body lift.
or a 2" rough country...if they make it for your year. not familiar with first gens
Old Oct 22, 2013 | 01:48 PM
Ok, so if the rear will lift up about 5", what can i do to the front? Im more or less trying to make tire clearence up front for the tires so they can turn
Old Oct 22, 2013 | 02:49 PM
newguy's Avatar
without buying a 5 inch lift kit or doing a solid axle swap, not much really
Old Oct 22, 2013 | 03:10 PM
87blazer4x4's Avatar
87blazer4x4 is on a distinguished road
yea kinda blows with the following the s10 has i cant believe theres not more avaliable. those dam toyota and jeep guys have everything... for cheap! lol
On the first gens especially in 87 unless you have an engine swap the 2.8 is gonna be extremely underpowered with 32's especially agressive ones even in 4LO. thats why im sticking with 31's and the 2.5 rough country lift until i have the money for a sas and the time to put my v8 in gonna be awhile though.
Old Oct 22, 2013 | 04:13 PM
newguy's Avatar
you can do add a leafs which are fairly cheap, will give you an easy 2 inches and help the ride also. pretty sure they are under 50.00
Rancho Part RS60612 - Add-A-Leaf Kit Rear - Fits 1976 to 1986 CJ - 4 Wheel Parts
The page say it will fit your truck
Old Oct 22, 2013 | 04:22 PM
Diaita's Avatar
There are lots of lift kits and SAS kits available for about the same money as Toyota and Jeep stuff.
FourX4 00
Lifting Tech
21
Jan 28, 2010 09:19 PM
drogg1
Lifting Tech
Jan 20, 2010 11:43 PM
toby42
Lifting Tech
Feb 21, 2008 02:32 PM
mudsliner
Lifting Tech
May 25, 2007 11:23 PM
danr
Suspension Tech
Jul 10, 2005 03:46 AM
