Checking front end for loose parts
Old Oct 6, 2008 | 08:08 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Checking front end for loose parts
97 Blazer LT 4 DR., 4.3ltr. 145k miles, 4x4. What is the correct way to check the front end for loose parts. I've heard wheels off the ground and moveawheel back and forth. I've heard wheels on the ground and pull the center link up and down. I do need front end work but I want to replace what I canmyself, before I take it in and they tell me it will cost $500 bucks.Here's what I know, and have replaced already: Upper and lower ball joints, {Moog} Idler arm, {Moog} problem solver. The other parts I'm just not sure how to go about how to chek them. Feel for slop at the joints? Any help on thisis always appreciated, Thanks.
Old Oct 6, 2008 | 08:14 PM
Default RE: Checking front end for loose parts
Depends on what you are checking. Some items cannot be checked with weight on the wheels and some require weight..
Ball joints can be checked either way. Uppers are easier to check with the wheels on the ground while lowers are easier with the weight off.
Tie rod ends are easily checked with the vehicle on the ground, but just as easy to check with the front end up in the air.
Wheel bearings are much easier to check with the weight off of them.
Old Oct 6, 2008 | 08:36 PM
gmbwrenchn's Avatar
I guess to be specific, pitman arm and inner and outer tie rods I want to check. The rest have been replaced recently, Thanks.
zcat23
Sep 29, 2010 10:30 AM
chevyblazerfan
May 6, 2010 12:34 AM
ussexplorer
Apr 11, 2010 06:53 PM
jdpilot
Feb 24, 2008 09:57 PM
tammikm
Oct 6, 2005 09:59 AM
