clunking issue when making tight turns
Old Nov 20, 2015 | 06:55 PM
hylander6361's Avatar
hylander6361 is on a distinguished road
Default clunking issue when making tight turns
hey all,
another small issue for you guys, i noticed when i bought my blazer a few weeks ago that it clunks when i make tight corners, usually just one noticeable clunk each time you turn tight. im not sure if it does it both left and right but for sure does it when i turn tight to the left. since ive bought it i had all 4 ball joints done, pitman arm, idler arm, and new hubs up front. i also know that the guy before me had just replaced the sway bar links. which i can confirm because i looked.
what could this be?
thanks
Old Nov 20, 2015 | 08:07 PM
richphotos's Avatar
*moved to steering, suspension & drivetrain*
Please make sure you post your question in the correct sub forum, thank you.
Old Nov 20, 2015 | 08:35 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
Check your hood hinges by grabbing the hood and try to move it side to side and back in forth.If you here it clunking?That could be your problem.
Old Nov 20, 2015 | 10:09 PM
i dont know if that would be the issue, ive never had it happen other then when turning very tight. and its normally just one clunk noise
Old Nov 21, 2015 | 07:04 AM
Toocute350's Avatar
Then it probably maybe a cv axle.
Old Nov 21, 2015 | 06:12 PM
great, i just had it all apart to do the hubs, brakes, ball joints, pitman arm, idler arm, and now the CV decides its the weakest link.... FML
Old Nov 21, 2015 | 08:01 PM
odat's Avatar
usually a CV joint in a bind from a tight turn or failing makes a constant rattle all the time its bound in the turn not just one thump - I would check the worm gear mounting bolts, A arm bushings and mounting points of the A arms, check for shiny spots around mounting points for body, radiator support ect. shiny spot means movement - check around worm gear mounting point on the frame and other mount points for cracks, look it over for anything that looks abnormal
Old Nov 23, 2015 | 05:16 AM
LannyL81's Avatar
hylander6361: my '02 does the samething...I hear one pop usually when backing-out of a parking spot and in a tight turn. I have replaced both CV axles and still does it. I have yet to determine what the cause is.
If you find something let me know and I will do the same.
Old Nov 29, 2015 | 10:33 AM
Aeromaster's Avatar
Aeromaster is on a distinguished road
Aftermarket balljoints usually require drilling out OEM rivits and replacing with hardened bolts, nuts. Bolt diameter may be smaller than drilled rivet hole and could allow the ball joint mount to slip or clunk where it attaches to the control arm
jobiscomplete
Dec 5, 2012 04:48 PM
JetJock79
Apr 21, 2011 03:44 PM
musclecar70sfan
Nov 7, 2010 08:48 PM
magsmom
Feb 19, 2009 11:57 AM
Lockback
Aug 22, 2007 12:24 PM
