Clunking noise
Old Jan 12, 2017 | 11:11 PM
Kingjames's Avatar
Kingjames is on a distinguished road
Default Clunking noise
Hi guys I have a 2001 Chevy blazer 4x4 there's a clunking noise at low speeds accelerating and decelerating and turning right I know it's coming from the front drive shaft for sure it's either from the transfer case or from the cv joint on the shaft connecting to the transfer case but not for sure if that's the problem not wanting to spend 200$ on the part and have it still be coming from the case or the yoke so any tips or information is appreciated thank you for the help in advance
Old Jan 13, 2017 | 03:28 PM
Check your upper control arm mounting bolts/nuts. I had a sound that happened under very similar circumstances and my left rear-most upper control arm mounting nut was hand tight :/ Had just had an alignment done too...
mikol23
29
May 13, 2010 02:49 PM
99whiteblazer
Feb 15, 2007 03:01 PM
jamesvre
Feb 19, 2006 07:18 PM
Blazin 4x4
Oct 23, 2005 06:11 AM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
